joshduguid999
Aug 04, 2018Aspirant
Audio-over-Ip on NETGEAR m4300 Switch mDNS & SAP
Looking for help, since apparently Netgear charges $100 just to talk to support for a switch I purchased less than 3 months ago.
Configuration is as follows:
m4300-96x switch stacked with two...
- Aug 08, 2018
Hey,
So what I had to do to get IGMP working properly was configure things under the IP(routing)/Multicast settings. Make sure the global configuration is on, the IGMP global configuration is on, and configure your VLAN under interface settings. That should get IP based IGMP working for you.
Under "switching/multicast" is only L2 IGMP, which might be why you're having issues with Dante.
LaurentMa
Aug 05, 2018NETGEAR Expert
Hi Josh
Sorry about this issue. We are going to fix it.
After 90 days of phone support, you are entitled with lifetime chat technical support. But don't worry, our Tech Support team is coming to you using private message.
Yes, we fixed mDNS issue, entirely, years ago in our M4300 switches with IGMP - and our brand new M4300-96X shall be no exception. Stay tuned!
- atianAug 06, 2018Aspirant
Hi Josh,
we tested it in lab and couldn't see your issue. could you post the techsupport file?
you can go to the GUI: Maintanence-> Export-> HTTP file export, select techsupport file, and click the 'Apply' button.
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
