joshduguid999
Aug 04, 2018Aspirant
Audio-over-Ip on NETGEAR m4300 Switch mDNS & SAP
Looking for help, since apparently Netgear charges $100 just to talk to support for a switch I purchased less than 3 months ago.
Configuration is as follows:
m4300-96x switch stacked with two...
- Aug 08, 2018
Hey,
So what I had to do to get IGMP working properly was configure things under the IP(routing)/Multicast settings. Make sure the global configuration is on, the IGMP global configuration is on, and configure your VLAN under interface settings. That should get IP based IGMP working for you.
Under "switching/multicast" is only L2 IGMP, which might be why you're having issues with Dante.
kohdee
Sep 20, 2018Administrator
Hi! Based on this community post, we created this. Hopefully it helps you configure your NETGEAR switch with Dante devices.
https://kb.netgear.com/000060205/M4300-Configuration-Guide-for-Dante-Audio-Devices
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
