reisley
Oct 24, 2024Tutor
AV profile discrepancy between M4250 and M4350
Products: M4250-40G8XF and M4350-24F4V (current firmware for each, 13.0.4.26 and 14.0.2.23) There are significant discrepancies between the AV Profiles in the two series of devices and I am not cer...
- Oct 25, 2024
Hi reisley ,
There are two things:
1. Shure has qualified (tested, QA etc.) the Shure profiles on M4250 switches, and we are still waiting for their validation on M4300 / M4350 switches, although we know they would work. This is why we don't show the Shure profiles available on M4300 / M4350. But yes of course, it's Dante, and you are going to use another Audio profile that will work just fine.
2. Please run the latest firmware version and AVUI version on M4250 and M4350 in your case. 13.0.4.26 is the latest firmware for M4250 at https://www.netgear.com/support/product/m4250/#download
But to have the same AV UI and the same behavior in the profiles (PTP TC time stamping etc.) please upgrade your M4350 switches to 14.0.2.26 at https://www.netgear.com/support/product/m4350/#download
This way, except Shure, all other profiles will be in sync.
In your case, I would not use a custom profile. Instead, I would delete extra VLANs and only keep the Default VLAN 1 on all switches. And edit the Default VLAN 1, applying the Audio Dante template to it each time. You will notice the PTP residency time stamping (PTP-TC) slider then, you can enable or disable the PTP-TC - but it needs to be the same on every switch.
With the latest .26 release, the PTP-TC (PTP residency time stamping) is available everywhere at the profile/VLAN level.
It is important to have the same FW/AV UI version for an AVoIP installation. You can also our Engage controller (www.netgear.com/engage) for configuring all switches at once.
I hope it helps!
Laurent
LaurentMa
Oct 25, 2024NETGEAR Expert
Hi reisley ,
I hope it helps!
Laurent
reisley
Oct 25, 2024Tutor
Thank you, I did not see that a newer version of the M4350 firmware has been released since my project started.
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
