chapps76
Nov 29, 2022Aspirant
AVB License for M4250-10G2XF
Hi - I have the above switch and need to buy an AVB license for it. There is a lot of confusion (at least for me) caused by websites offering the AVB license for sale. Please can you help clear u...
- Nov 29, 2022
Hi chapps76 ,
The ordering SKU information for M4250 switches and their AVB licenses can be found starting page 62 of the M4250 datasheet. I hope this will help you.
Yes, AVB licenses are perpetual. When you install the AVB license into the switch, it will stick - even in case of factory reset the switch will keep it. When there is an AVB license in the switch, you can use the AV UI and edit the Default Profile VLAN 1 for instance - applying the AVB template to it. This way, all ports now can do AVB.
Yes, AVB licenses are worldwide electronic SKUs so it can be procured in any region. M4250 switches also are the same in any regions, only local power cords are placed in localized versions.
Usually, M4250 pricing is meant to be the same across all geos - so I am not sure about your research. Please make sure to procure NETGEAR AV Line switches and licenses at an approved NETGEAR reseller/partner. I wouldn't want to you to run into trouble? but anyway, we are here to support you. You can always reach out to us at [email protected], by email.
chapps76
Ok - so it seems I may have figured out the difference between the 2 licenses - the PX is for the POE+ and UX is for POE++
Just trying to get clarification on the other points now!
- DaneANov 29, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
Yes, you are correct. As a reminder, the AVB licenses are model specific so make sure that you purchase the AVB license that corresponds to the specific switch model.
As reference, kindly check the table below:
DaneA
NETGEAR Community Team
- LaurentMaNov 29, 2022NETGEAR Expert
Hi chapps76 ,
- chapps76Nov 29, 2022Aspirant
Thanks guys - huge help
John.
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
