AW_GearNet
Jul 19, 2017Guide
GS724Tv4 and AVB
I have a Netgear GS724Tv4 ProSafe 24-port Gigabit Ethernet Smart Switch.
Software version loaded is 6.3.1.11.
License with following features
- MRP
- MMRP
- MVRP
- MSRP
- DOT1AS
is activated.
I paid more than half the price of the hardware for activation of AVB on my switch. Usually AVB is open-source and free.
Is this switch fully compatible, compliant, conform and interoperable with AVB as per specification from avnu.org and IEEE?
Would/does this switch pass the test for certification as per http://avnu.org/recognized-test-facility/
How to configure and set-up the switch to make it the best suited for AVB?
Please give a honest and sincere answer to my questions. This will/would prevent/avoid a lot of unnecessary troubles and their shootings.
Do not just delete my post!
Thanks.
Andreas WERNER
CH-9658 Wildhaus
Switzerland
Hi AW_GearNet,
Welcome to NETGEAR community!:smileyhappy:
1. How to configure and set-up the switch to make it the best suited for AVB?
Answer:
Please reference following documents to deploy AVB/EAV.
GS724T Ethernet Audio Video administration guide
GS724T software administration guide. --->Page 131.
2. Is this switch fully compatible, compliant, conform and interoperable with AVB as per specification from avnu.org and IEEE?
We had become a member of avnu.org.
You can check it from http://avnu.org/our-members/
Maybe the solution help you:smileyhappy:
- JohnC_VNETGEAR Employee Retired
Hi AW_GearNet,
I'm not that really sure if this would be compliant to avnu.org as this AVB license is already a 3rd party software. Were you able to confirm this to avnu? Maybe they do have a list of switches that they recommend or already compliant to their system. So that we can verify if the switch that you have would be compliant to them.
- DanielZhangNETGEAR Expert
Hi AW_GearNet,
Answer:
