simonszu's avatar
simonszu
GS724Tv4 enable sntp
Hi,
currently i am struggling with enabling SNTP on the GS724Tv4. I have added an SNTP server on System>Management>Time>SNTP Server Configuration and enabled Daylight Saving Time Configuration. I set the clock source on Time Configuration to SNTP, and no matter if i set client mode to Unicast or Broadcast, after i click Apply the page refreshes and the setting is set back to Local. Is there something missing or how can i properly set the Time mode to SNTP?
FW Version 6.3.1.16
Thanks in Advance
  • I was able to resolve this issue with upgrading to Firmware 6.3.1.19
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi simonszu,
    Welcome to our community!
    You may need to setup first the time server in order for it to work properly. You may also upgrade the firmware of the switch to its latest version.
    Here is one of the articles on setting up SNTP. You may check it here.
  • JohnC_V's avatar
    JohnC_V
    simonszu,
    I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance.
    • simonszu's avatar
      simonszu
      • JohnC_V's avatar
        JohnC_V
        simonszu,
        That's great! Thank you for sharing that here in our community! The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
