Brent_Gutmann
May 13, 2021Follower
Cannot Connect with Birddog P100 or P200 through stacked M4250-10G2XF-PoE+ & M4250-12M2XF
Stacked M4250-10G2XF-PoE+ this week with M4250-12M2XF using an SFP+ patch cord. I have not updated the firmware, nor have I been able to figure out how to get into either switchs' GUI, but my real p...
endurorider
May 14, 2021NETGEAR Expert
Hi Brent,
OK so the first thing you want to do is update the firmware on that switch. To do that you need to be able to login to the switch. The easiest way to do this in my opinion is to connect to the OOB port on each switch which has an IP of 192.168.0.239. You just need to set your computer's LAN port to something on the same subnet like 192.168.0.23 255.255.255.0 and you should be able to get to the GUI.
Once you're able to get to the GUI you can type 'admin' for the username and leave the password blank and hit 'enter' and that should prompt you to create a new password. Log back into the switch and go to Maintenance - Upgrade - HTTP File Upgrade and browse to the firmware file and click Apply. Once the firmware is loaded successfully you can go to the Reset tab and reboot the switch and you're all set.
Do this for any and all switches first and see if the resolves the issue.
You can download the firmware here:
https://www.netgear.com/support/product/MSM4214X.aspx#download
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
