goudeuk
Jan 24, 2023Aspirant
Command line help
Hello everyone Could someone please explain, what is the difference between: switchport access vlan 5592 and vlan participation include 5592 I'm aware what switchport access vlan 5592 does bu...
- Jan 25, 2023
Hi goudeuk ,
đ What do you mean by, "not free"? If you update the firmware of your M4250 switch like I told you above, you will see the AV UI login when connecting to the switch P address in your browser. The AV User Interface comes standard with M4250 and M4300 switches for AV over IP applications. Please visit www.netgear.com/proav and more specifically this: https://www.netgear.com/business/solutions/proav-resources/listing-filter/video/
You'll see plenty of videos and I hope, it will make you impatient to use it instead of our IT CLI?
goudeuk
Jan 25, 2023Aspirant
Dear Laurent
Thank you for your reply. I was not aware about the AV UI but I suspect is not free. Is there a demo page I could have a look at?
LaurentMa
Jan 25, 2023NETGEAR Expert
Hi goudeuk ,
- goudeukJan 25, 2023Aspirant
Hi Laurent
I misunderstood you. I thought you were referring to a new UI, separate from the UI that comes with the switches. Anyway, confusion cleared now, thank you.
Also, thank you for the link, I already found a video that would be useful to me, e.g. "NDI switch config".
Have a good day.
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
