RParfait
Jan 27, 2025Aspirant
I reset my M4250-26G4F-POE++ and now it is pinned to a full fan speed
I reset my M4250-26G4F-POE++ and now it is pinned to a full fan speed, I was trying to log into the GUI but I couldn't, so I decided to do a reset using the reset button at the back and now it is on...
LaurentMa
Jan 27, 2025NETGEAR Expert
Hi RParfait,
I am sorry for your issue, to me a software upgrade was interrupted and now the switch is "bricked".
Can you follow my previous indications here: https://community.netgear.com/t5/Pro-AV-over-IP-Switches/M4250-pinned-at-full-fan-speed/td-p/2378150
If the issue persists, please email [email protected] and one System Engineer will come back to you and help you fix it (the switch needs to be downgraded, and when all ports are fine again, re-upgraded to the latest).
Laurent
- RParfaitJan 27, 2025Aspirant
Hello,
thank you LaurentMa
usually how long does it take to reset and operate normally? or is there any configurations required after pressing that reset button?
- LaurentMaJan 27, 2025NETGEAR Expert
If the switch is fine, 120 seconds after hard reset before the traffic starts flowing.
But in your case, the software might be corrupt, this is why I think you need to install the USB driver ( https://www.netgear.com/support/product/m4250/#download ) and observe the console during boot. I think the switch needs to be re-flashed. If the steps during my previous post I indicated to you aren't working, please email [email protected]
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
