Ireah
Aug 14, 2025Aspirant
Is this config OK?
Dear colleagues,
I am planning to use a M4250 switch for NDI and internet. I have created 2 VLANs, as follows:
Default VLAN (1): 192.168.50.2. It is used for control and internet. I have set it as static with DHCP server and DNS
NDI VLAN (10): 192.168.10.2. Used for NDI devices. It is set as static with DHCP server and no DNS, so devices in this VLAN can't access internet.
In my Peplink router, I have set 2 VLANs as well:
Default VLAN: 192.168.50.1
NDI VLAN: 192.168.10.1
Inter-VLAN is enabled on both
My question is:
When configuring the Default VLAN on the Netgear switch, Does it make sense to choose 192.168.50.2 as the VLAN IP address, since my Gateway is 192.168.50.1? (see attached picture)
I have seen people use the same IP for both VLAN address and Gateway, and I am confused here.
Would the same thing apply to the NDI VLAN? (choosing 10.2 and leaving 10.1 for the Gateway)
Thanks a lot,
Ignacio
No RepliesBe the first to reply
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
