Barrygast
Mar 22, 2024Aspirant
M4250-10g2f Keeps rebooting
Hi All, I'm experiencing some issues with my M4250 I tried to factory reset with the button on the front, after this the switch keeps rebooting/crashing every 1/2 minutes. Has anybody ex...
LaurentMa
Mar 22, 2024NETGEAR Expert
I am sorry for your issue, this is very unusual. To me the switch software got corrupted and we just need to help you reflash it. If it doesn't work, then we will replace it for you.
This forum is not a tech support site. Better to send us an email at [email protected] and one SE will assist you today.
Barrygast
Hi Laurent,
Thanks I have sent them a e-mail.
I do have another question.
i've made a shure controll network.
My shure devices see each other. But my computer on the other hand, does not. When I bypass the netgear, everyting works fine on my computer. Do you have any idea perhaps?
Thanks!
- LaurentMaMar 22, 2024NETGEAR ExpertIn the AV UI (or better, Engage controller), you should apply the Shure Converged AV template to the VLAN you are using (for instance VLAN 1).
If your computer is a Mac, you can go to the AV UI and go to Configure/Multicast. Click the port where your computer is, and activate "Force Multicast" mode on it. Click apply and save!
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
