dvandemaele
Sep 29, 2024Aspirant
M4250-26G4F-PoE+ showing fiber ports as SFP instead of SFP+
Firmware Version 13.0.4.23 AV UI Version 2.2.7.36 Boot Version 1.0.0.12 Hello, everywhere I check the specs for this switch, it indicates that the 4 fiber ports are 10G SFP+ W...
- Sep 29, 2024Hello, this switch has 4 x 1G SFP ports, please check the datasheet here?
https://www.downloads.netgear.com/files/GDC/M4250/M4250_Datasheet.pdf
With the latest firmware, only 1G transceivers can be used. Did you use 10G transceivers before? I am afraid it was wrongly showing 10G speed, but actual speeds were 1G only, as the ports are 1G.
You can use the XF models (SKU numbers with a "X" at the end for 10G uplinks (SFP+)
Please let us know!
LaurentMa
Sep 29, 2024NETGEAR Expert
Please let us know!
Please let us know!
dvandemaele
Sep 30, 2024Aspirant
Wow totally missed that, and thanks for the quick reply!
I assumed that the switches would Auto negotiate 1G... but it appears that my M4250-40G8XF have the port configuration speed set to 10G and can't be changed to Auto or 1G
So does the M4250-40G8XF can only accept 10G, and the M4250-264F can only accept 1G?
thank you,
Denny
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
