rward2801
Oct 20, 2021Follower
M4300-96X HIGH CPU Utilization
Hello Netgear Community
I have a M4300-96X ProSAFE 96-port 10G switch designated as the core switch in an enviroment that
ProAVDesign@netgear.com designed & configured.
This device is running at a VERY high CPU utilization.
I need some asstiance to get this replaced or resolved as it is impacting our customer.
Memory Utilization Report
status KBytes
free 1176568
alloc 879684
CPU Utilization:
PID Name 5 Secs 60 Secs 300 Secs
16 (kworker/0:1) 0.00% 0.09% 0.08%
1480 (procmgr) 0.19% 0.04% 0.06%
1572 hwMonTask 0.00% 0.01% 0.01%
1581 osapiTimer 0.00% 0.00% 0.01%
1585 bcmINTR 3.70% 3.26% 3.28%
1588 bcmL2X.0 5.85% 5.60% 5.59%
1590 bcmCNTR.0 4.68% 4.36% 4.53%
1593 bcmLINK.0 5.46% 5.27% 5.25%
1596 bcmRX 9.17% 9.20% 8.81%
1609 cpuUtilMonitorTask 0.19% 0.23% 0.23%
1619 tap_monitor_task 0.00% 0.01% 0.14%
1624 simPts_task 0.19% 0.10% 0.04%
1632 emWeb 0.19% 0.12% 0.36%
1634 dtlTask 1.95% 1.31% 1.22%
1637 hapiBpduTxTask 0.19% 0.09% 0.05%
1638 hapiRxTask 0.58% 0.97% 0.95%
1652 trafficStormControl 0.00% 0.02% 0.01%
1658 SNMPTask 0.00% 0.04% 0.40%
1681 snoopTask 1.75% 1.41% 1.52%
1714 ipMapForwardingTask 56.23% 56.03% 54.94%
1720 openrTask 0.58% 0.95% 0.99%
1744 mgmdMapTask 0.19% 0.06% 0.04%
1754 ip6MapLocalDataTask 0.00% 0.03% 0.03%
1761 lldpTask 0.00% 0.14% 0.21%
1770 isdpTask 0.00% 0.10% 0.05%
1773 RMONTask 0.19% 0.89% 0.77%
1794 StatsAppTask 0.78% 0.76% 0.75%
1832 poe_monitor 5.46% 6.78% 6.81%
Total CPU Utilization 97.62% 97.77% 97.21%
1 Reply
- LaurentMaNETGEAR Expert
Hi rward2801 ,
Thank you for posting here, please send the tech-support file out of this switch to ProAVDesign@netgear.com so that we can see what is causing the high CPU utilization. It may be time sensitive networking (clocking? PTP?) or IGMP reserved packets hitting the CPU. We will first inspect the logs and the troubleshooting commands output in that file and get back to you. Don't worry, we will find the root cause and help you fix it.
Please use the GUI and go to Maitenance\Export\HTTP File Export\ and select Tech-Support in the dropdown menu list. Please send us this text file at ProAVDesign@netgear.com -
Thanks!
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
