danieloo
Feb 03, 2025Follower
M4300 IGMP Snooping and Report Flood Mode
In an AV network with multicast streams, I have an M4300 switch which has IGMP snooping enabled. Multiple hosts connected to that switch joined the multicast group 239.1.1.1 and sent their initial un...
schumaku
Feb 11, 2025Guru - Experienced User
Is this flood probably related to an STP routing change and the following election process? Typically it is STP TCN! Sure, the Flood mode -must- be retained active to stay within the RFC/standardisation since it's required, this is why it's on by default.
On Cisco swiches, you would issue an ...
no ip igmp snooping tcn flood
...on all switch uplink ports.
LaurentMa explined this and more in-depth here for the Netgear Managed switches.
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
