RandyL
Dec 12, 2019NETGEAR Expert
NETGEAR IGMP Plus Whitepaper
What is NETGEAR IGMP Plus™? NETGEAR’s AV Line M4250, M4300 and M4500 fully-managed switches provide a unique feature called IGMP Plus. This feature greatly simplifies system architectures by enablin...
CrazyGoose
Dec 08, 2021Aspirant
Great whitepaper but I would love to know where the information is based on that you need 14 steps to configure IGMP in a GigaCore 26i as this is enabled by deafault?
schumaku
Dec 08, 2021Guru - Experienced User
It's not about "just2 enabling IGMP. There is a Cisco-like sample config shown above the table. hard to imagine this is already there in place.
- CrazyGooseDec 08, 2021Aspirant
By default, in every group/vlan already available in the switches (20 are pre-made for you) the IGMP querier and snooping are enabled by default. The global settings have IGMP unknown flooding enabled so all you would have to do is disable this or disable it in a group which will not take 14 commands hence why I would love to know where that number is comming from?
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
