joelp1212
Jan 26, 2026Aspirant
PC sending NDI to another PC...what QOS ?
We have a PC1 sending video using NDI app to Another PC2(receiver). PC1 is on Port 10, PC2, is on port 20. We assigned Port 10 to Queue 5, but we have no idea if this is even working or if we ...
schumaku
Jan 26, 2026Guru - Experienced User
joelp1212 wrote:What should the Global Trust Mode setting be? Trust dot1p or IP-DSCP?
None of these required, as long as you don't have a bigger L2 switching or L3 routing environment where you have to trust neighbouring switches and routers?
joelp1212 wrote:Do we modify anything in 802.1p to Queue Mapping 802.1p Priority for such a setting?
Do we modify anything in IP DSCP to Queue Mapping ?
No, and no - see above why... No idea why you think you have to customize things not applicable for your use case.
joelp1212 wrote:Lastly how can we verify if the settings are working correctly?
What about -testing- this simple ptp NDI connection?
Starting with the very basics, for a simple point to point NDI (NDIHB or NDIHX) connection, any unmanaged Gigabit switch can do the job easily - so no rocket science is required.
Some popular applications like vMix are supporting Statistic for all NDI inputs and outputs, that's a good place to start.
For helping and testing, the NDI Tools are coming with the ability to generate NDI test patterns on a computer..
If you are keen looking into the NDI processing, start there -> NDI Analysis Tool The NDI Analysis is a command line utility that enables experienced users to delve into the performance of NDI network connections and troubleshoot issues in any workflow.
joelp1212 wrote:We assigned Port 10 to Queue 5, but we have no idea if this is even working
Why oh why please? Stick with the basics, especially in case you are not a hardcore switch engineer. Any believe me: If you are assigning incoming frames to a certain internal switch queue, the switch will very likely do as you desire.
Configure the VLAN, the switch ports, and assign the required profile(s). It's not difficult - see later on for the config example documentation, and make use of the free tools available.
joelp1212 wrote:We have a M4300 series switch
Exact model and installed firmware makes a good starting point in a community please - then experienced community members (most are neither paid nor supported in any way by Netgear) are happy to help out.
A well ment advise: Instead of loosing yourself in the virtually thousands of pages from the various M4300 documentations, head to https://www.netgear.com/support/ - select the switch model you intend to configure. Start from the Configuration Example Guide for ProAV Installations
Helpful is always to have the free Netgear Engage Controller software installed on a computer.
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
