mediazone's avatar
mediazone
POE++ Injector with M4250
Hello, I have a M4250 with POE+
3 of my cameras need POE++, is it possible to use a POE++ injector with my M4250 and still pass thru NDI Video?
I know there are POE++ switches available, but we had budget for the 24 port GSM4230P and so trying to work around that. Thank you
  • schumaku's avatar
    schumaku
    Yes, of course. This is the advantage of industry standard PoE (vs. proprietary passive PoE). The M4250 won't provide power if there is no compliant PD (powered device) - so there is no added risk people are often concerned. The plain Gigabit Ethernet connection will be retained "through" the power injector. What you are loosing is the network-side control of the power on these ports.
    • mediazone's avatar
      mediazone
      Thank you, so if Im understanding correctly, a PTZ camera will lose the control functions?
      • schumaku's avatar
        schumaku
        No, of course not. The PTZ controls are almost certainly embedded in the Gigabit Ethernet data stream.
        What you can't do is eg. triggering a power reboot in case your device will hang one day,
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
ProSupport for Business
