MinkaM
Jan 26, 2024Aspirant
Problems with trunking on multiple AV-line switches
I have a system where as a "centre device" I have M4250-40G8F, and then on top of that I have 5pcs of M4250-40G8F and 1pc of M4250-10G2XF. All switches, except the small one are having 3 VLANs (Dante...
LaurentMa
Jan 26, 2024NETGEAR Expert
Hi MinkaM ,
The Auto-LAG and the Auto-Trunk should be enabled across your site on all switches. If there is a problem, maybe it's coming for your modules (layer 1 connectivity, unsupported modules?).
Can you take a look at the corresponding application note to check your configuration so far:
AV over IP Technical Guides - NETGEAR
In Engage, all trunks should show the "A" icon on the ports. Please send an email to the ProAV Design team with all the tech-support files (one per switch) and a link to this post. The Engage Controller lets download all TS files at once, there is a tab for it. If this a module issue, a cabling issue, or something else, we will be able to easily see this in your TS files, and one of ProAV Design SEs will get back to you.
MinkaM
Thanks for promt reply!
I have Auto-LAG and Auto-Trunk enabled, and as said, most of the lines finds themselves, but looses after a while.
I will let the system on for weekend and see on Monday what it going on there. I will also check on Monday those SFP-modules that they are fully supported.
I will come back to this on Monday, as I am just about to go for a weekend 🙂
Br,
-Minka-
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
