Pumpkinking's avatar
Pumpkinking
M4250 switches - AMG731F 1G SFP module in 10G SFP+ slot
Hello, I am trying to link an AV Line M4250-10G2F-PoE+ (GSM4212P) to an M4250-26G4XF-PoE+ (GSM4230PX), using 2x AMG731F 1G SFP Modules,   The 10G SFP+ port in the 26G4XF does not seem to like ...
  • MikeD1234's avatar
    Jan 20, 2023
    Hi George,
    Both the M4250-10G2F-PoE+ (GSM4212P)  and the M4250-26G4XF-PoE+ (GSM4230PX), support the AGM731F module, and, the M4250-26G4XF-PoE+ has four ports whichs are SFP+ but, they should auto negotiate to 1G or 10G, depending on what's connected at the other end.
    If you can forward your Tech Support files from both switches, with the fibre connection connected, to the ProAV Design team, we will help you get this resolved.
    You can reach the Pro AV design team on proavdesign@netgear.com and one of the team will help you get this resolved.
    Thanks!
    Michael Dijk
    NETGEAR System Engineer, Pro AV
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
ProSupport for Business
