mshahnawaz
Sep 16, 2020Aspirant
Required all Multicasts on one port
Hello Experts, Can someone please suggest the best way for my situation mentioned below? I am using M4300-28G running version 12.0.11.11. I have IGMP snooping and IGMP Querier working fi...
mshahnawaz
Sep 17, 2020Aspirant
I have already tried setting IGMP on interfaces manually but seems like IGMP Snooping on interfaces isn't doing anything and only IGMP global settings are taking effect. Regardless of what I do on interfaces it doesn't change anything.
Please advise.
Muhammad
- LaurentMaSep 17, 2020NETGEAR Expert
Hi Muhammad,
Thank you for your message. I can feel the emergency here, please contact the ProAVDesign@netgear.com team by email for rapid assistance, it will be faster and more practical than the Community forum.
On your two M4300 switches, please upgrade to the latest in first place: 12.0.11.15
https://www.netgear.com/support/product/m4300.aspx#download
Please make sure the new 12.0.11.15 is loaded to Image-1 or Image-2 which the next boot image; if you're not sure please load 12.0.11.15 into both Image-1 and Image-2.
Default configuration comes with IGMP Plus configured globally, at the VLAN level (VLAN 1).
You DON'T want to use port based IGMP configuration when there is VLAN-based IGMP configuration already. This is going to conflict. It is better to stick with the VLAN config. If you want to configure IGMP at the port level, then we must first remove any configuration at the VLAN level.
IGMP isn't meant to flood all Multicast to one specific port. I don't think you mean that for port 25. I believe you need the Mrouter mode enabled on port 25 (10G port) in order to let the multicast traffic go between switch 1 and switch 2.
With the default configuration and latest 12.0.11.15, this is the expected and intended behavior out of the box. Any port connected to another IGMP Plus-enabed switch will have an automatic mRouter mode that will let the multicast traffic go when there as receivers subscribing to it on the other side.
So please upgrade to the latest 12.0.11.15 both switches, and please FACTORY-DEFAULT both switches going to Maintenance/Reset.
I trust this will work just fine out of the box this way, with the interconnect on port 25.
Again, please contact ProAVDesign@netgear.com by email, we will assist you the best we can right away.
I hope this helps
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
