JohnD333
Feb 10, 2021Apprentice
Allow a “fixed” connection to specific Satellite versus Router Master SXR80
I must power cycle my WiFi devices that do not move whenever OrbiPro6 reboots. Upon reboot (firmware update, configuration change, or just troubleshoot) it is understood that it is “normal” for the ro...
stevethompson
Feb 11, 2021Star
Or maybe set it up such that nothing can connect until the router and all satellites have completed the reboot.
- schumakuFeb 11, 2021Guru - Experienced User
The appropriate approach (as implemented on the WAC5xx and WAX6xx APs) would be a feature allowing to disassociate sticky clients (remaining connected to a bad signal). This would help "dumb" (non 802.11k/v/r aware) wireless clients to re-establish a connection to the best BSSID (the best radio available) for the configured SSID.
