ShannonC
May 11, 2021Tutor
Android Apps cannot reach IoT devices
I just installed Orbi Pro Wifi 6. I have enabled all 4 SSIDs (default, employees, IoT, guest) and have setup devices in each. Pulling my hair out trying to get everything working. I am having the fo...
- May 11, 2021
Correction
Port 3 is IoT VLAN Profile with Access set not Trunk.
BruceGuo
May 11, 2021NETGEAR Expert
If wireless Android phone can discover wired IoT devices in the same VLAN profile but not able to discover in different VLAN profile. It could be:
(1) Isolation features in VLAN profiles are on
(2) IoT devices use mDNS protocol that cannot support inter-device communication across subnets
If you know you hit (2), see if you want to try trial firmware that support mDNS communcation across subnet.
schumaku
May 12, 2021Guru - Experienced User
BruceGuo wrote:If you know you hit (2), see if you want to try trial firmware that support mDNS communcation across subnet.
Congrats for making it happen - a mandatory feature for the intended design and usage 8-)! Version number and availability please. Last Pro WiFi 6 firmware on the Orbi Pro (Beta) forum section dates from end of February 2021.
