Sc2111
Jun 07, 2023Aspirant
AX1800 VLAN Tagging not working
hhWe tried to configure an AX1800 with a second Wifi SID, for guests, with tagging but it seems not working. We configured the AP in "router mode" so to have access to the advanced "VLAN/BRIDGE" tab...
- Jun 07, 2023
The most simple AP supporting max four SSIDs and mapping to multiple VLANs (tagged of course) in the WiFi 6 AX1800 range is the WAX214v2 on a GbE LAN port, in the WiFi 6 AX4200 range WAX220 on 2.5 GbE, all nicely PoE+ powered.
Sc2111
Thanks for your reply that clarify a little the behavior of such AP ( WAX204 ).
Since we didn't use the WAN port, as this is an AP not connected to an ISP, and given the explanation provided it might work is we connect the WAN port to the internal switch with tagging enabled on the port ?
thanks
Stefano
schumaku
Jun 07, 2023Guru - Experienced User
Afraid no, this isn't the point. The WAX204 does not have any SSID<->VLAN mapping feature in AP mode, too.
- schumakuJun 07, 2023Guru - Experienced User
