mistercoffee's avatar
mistercoffee
AX1800 weak 5Ghz signal
Model: SXK30B3 / AX1800
(https://www.netgear.com/business/wifi/mesh/sxk30b3/)
Hardware Version SXR30
Firmware Version V4.0.1.100
Wireless settings:
Region North America
2.4G Channel Auto ( 1 )
2.4G Mode Up to 574Mb/s
5G Channel 149+153+157(P)+161
5G Mode
When I'm anywhere in my house, including standing right in front of the base station, my 2.5Ghz signal strength is excellent and my 5Ghz signal strength is about 2/5 bars. Speed on 5Ghz suffers accordingly.
Thoughts?
  • plemans's avatar
    what speeds are you getting?
    What device are you testing on?
    Have you tried other devices?
    Or tried a wifi scanner?
    Have you checked the router vs satellites strength on a scanner?
    • mistercoffee's avatar
      mistercoffee
      To reiterate, I'm talking about the base station router, no satellites.
      The signal strength on 5GHz (ie number of bars) is about 50% on a Macbook, Android phone, iPhone and Roku, all of them within a few feet of the router. This is true for each device when no other devices are on the 5GHz band.
      Speed test on the Macbook for 2.4GHz is ~240Mbps download. Same test, same device is ~67Mbps on 5GHz. No other devices are on the 5GHz band during this test.
      I have not tried a scanner -- what would I be looking for there?
      cheers
      • plemans's avatar
        huh, never even gotten close to 240mbps out of 2.4ghz.
        I've seen it done in lab conditions but never in real world conditions.
        Both my RAX200/RAXE500 peak around 120mbps in 2.4ghz. And that's peak. Usually its 50-100mbps on average.
        curious if maybe you don't have that reversed?
        what modem/gateway are you connected to?
        did you try a factory reset and testing with the default configuration? (not loading a backup or changing from default settings on the restore)
  • schumaku's avatar
    schumaku
    This could indicate the mobile does not connect to the nearest 5 GHz radio (or has a problem with the 5 GHz radio), the router 5 GHz might be inactive why ever, the backhaul might operate on the 2.4 GHz band, ... Very difficult to guess.
ProSupport for Business
