serney
Jun 12, 2023Aspirant
AX6000 WiFi Orbi pro SXR80 cpnnecting 2 routers (one onstead of a satellite)
Hi! I have the SXR80 Orbi pro router. Kindly advise - can I connect it not to a satellite, but to another same router, so that they extend the range and work (two paired SXR80 routers) the same as a ...
- Jun 12, 2023
Simple answer? No. you can't.
More complex, you can connect them together with the 2nd in AP mode but devices won't roam as easily/efficiently.
If you're truly wanting a mesh system, just use a router and the satellites.
serney
Jun 13, 2023Aspirant
And in terms of performance the second SXR80 will be on top (though without normal roaming), correct?
schumaku
Jun 13, 2023Guru - Experienced User
Sell-off the additional router, or keep it as a spare or test device. Of course, you could add the second router (which does add complexity) and operate it as a standalone access point.
- serneyJun 13, 2023Aspirant
The thing is that I have only one so far ))
But I cannot purchase a satellite here - only the second router... That's why I was asking all this questions.
Thanks a lot for your assistance.- schumakuJun 13, 2023Guru - Experienced User
In which market or country are you located?
Israel.
The place here to buy it is: https://www.senetic.co.il/product/SXS80-100EUS
They do not have a satellite any more (
And they don't know if they will have it or not any more...
