serney
Jun 12, 2023Aspirant
AX6000 WiFi Orbi pro SXR80 cpnnecting 2 routers (one onstead of a satellite)
Hi! I have the SXR80 Orbi pro router. Kindly advise - can I connect it not to a satellite, but to another same router, so that they extend the range and work (two paired SXR80 routers) the same as a ...
- Jun 12, 2023
Simple answer? No. you can't.
More complex, you can connect them together with the 2nd in AP mode but devices won't roam as easily/efficiently.
If you're truly wanting a mesh system, just use a router and the satellites.
serney
Jun 13, 2023Aspirant
The thing is that I have only one so far ))
But I cannot purchase a satellite here - only the second router... That's why I was asking all this questions.
Thanks a lot for your assistance.
schumaku
Jun 13, 2023Guru - Experienced User
In which market or country are you located?
- serneyJun 13, 2023Aspirant
Israel.
The place here to buy it is: https://www.senetic.co.il/product/SXS80-100EUS
They do not have a satellite any more (
And they don't know if they will have it or not any more... - schumakuJun 14, 2023Guru - Experienced User
According to my Swiss retailer, the SXS80-100EUS availability is announced for the time span between Fri 15.Sep. and Sat 14. Oct. No other choice than wait - calling for tikvah.
Will try to challenge the local Netgear rep to confirm.
- serneyJun 14, 2023Aspirant
Got it, thanks a lot!
What do you mean by "calling for tikvah"? - quagmire1Jun 14, 2023Luminary
- schumakuJun 15, 2023Guru - Experienced User
quagmire1 wrote:
Amazon US ships to Israel, and has the SXS80 in stock.
https://www.amazon.com/dp/B08FWLCGLW
Please allow a word of warning here:
Yes, Amazon does (by fat to often) cause problems by telling innocent customers that they can order on these channels. The devices listed on the US Netgear Store (on Amazon) are SXS80-100NAS models. Exporting US-FCC devices outside of the regulatory are is a bad idea for several reasons. These can't be configured to Europe (including Israel) standards - because of the the FCC regulatory does not allow the customer re-configuration.
For Israel (and greater Europe), only SXS80-100EUS can be deployed (and integrated with other Orbi Pro WiFi 6 systems using the local Web UI or on Insight.
- serneyJun 15, 2023Aspirant
No, unfortunately it is not currently available - please have a look at the screenshot.
- quagmire1Jun 15, 2023Luminary
When shipping to the US, that page shows "10 Left in Stock".
It appears Amazon will not ship that particular item to Israel - perhaps for the reasons another poster mentioned.
- schumakuJun 15, 2023Guru - Experienced UserAmazon does not care about shipping FCC models to different markets unfortunately - logistics seems to be to inexpensive nowadays, aside of causing useless support cases and disappointment for the customers. Probably there are multiple warehouses carrying the same deliverables, depending on the geolocation request.
I really tried the best to find it available anywhere here or for shipping to Israel. But, unfortunately, I haven't succeeded yet..
- schumakuJun 15, 2023Guru - Experienced UserChip shortage is still an issue in Summer 2023.
- serneyJun 22, 2023Aspirant
Yeah, I see (((
Hope that it hasn't stopped to be manufactured in general!!
- schumakuJun 23, 2023Guru - Experienced UserWe see expected delivery dates for SXS80-100EUS on the 18. June to 3. August time window here in Switzerland.
