serney
Jun 12, 2023Aspirant
AX6000 WiFi Orbi pro SXR80 cpnnecting 2 routers (one onstead of a satellite)
Hi! I have the SXR80 Orbi pro router. Kindly advise - can I connect it not to a satellite, but to another same router, so that they extend the range and work (two paired SXR80 routers) the same as a ...
- Jun 12, 2023
Simple answer? No. you can't.
More complex, you can connect them together with the 2nd in AP mode but devices won't roam as easily/efficiently.
If you're truly wanting a mesh system, just use a router and the satellites.
serney
Jun 15, 2023Aspirant
No, unfortunately it is not currently available - please have a look at the screenshot.
quagmire1
Jun 15, 2023Luminary
When shipping to the US, that page shows "10 Left in Stock".
It appears Amazon will not ship that particular item to Israel - perhaps for the reasons another poster mentioned.
