Asato
May 02, 2019Tutor
Can I setup multiple Orbi Pro Systems on the same Orbi Account?
Do I have to create a separate online account for each Orbi Pro system that I have in different locations?
JohnC_V
May 03, 2019NETGEAR Employee Retired
Hi Asato,
Welcome to our community! :)
If you are the original owner of the device, then, it should be registered under your name and the same account to avoid duplicates and confusion when it comes to warranty claims.
JohnCarloV
NETGEAR Community Team
- Apr 16, 2020Retired_Member
