Asato's avatar
Asato
Tutor
May 02, 2019
Can I setup multiple Orbi Pro Systems on the same Orbi Account?
Do I   have to create a separate online account for each Orbi Pro system that I  have  in different locations?
  • evan2's avatar
    May 13, 2019
    Asato
    You don't have to create a seprarate account,
    You may login Insight using your netgear account from insight.netgear.com or download Netgear insight APP from App Store and Google Play,
    and add multiple OrbiPro device in your Insight account.
ProSupport for Business
