emaniat
Mar 12, 2018Aspirant
Can the Orbi Pro and Orbi RBW30 Satellite work together?
Can the Orbi Pro work with the RBW30 satellite? Thanks.
- Mar 13, 2018
Hi emaniat,
RBW30 only works with Orbi Router RBR40 or RBR50. Orbi Pro SRK60 works with an add-on satellite SRS60.
Here is the datasheet of RBW30.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Mar 13, 2018NETGEAR Employee Retired
Hi emaniat,
emaniat
Mar 15, 2018Aspirant
Thanks for the info. Still new here and getting my feet wet. Will definitely use Accepted Solution when my questions are answered.
