Stables
Jun 17, 2022Initiate
Cannot update latest firmware 2.7.2.102 SRR60 and SRS60
Cannot do a manual update or automatic update from 2.7.0.122 to latest firmware 2.7.2.102 Auto update says "no new firmware update available" Manual update says firmware file is incorrect version.....
Jun 17, 2022Guru - Experienced User
When you're manually updating, are you making sure the router is getting the router version and the satellite the satellite version? I know it sounds stupid but I've seen people trying to install the satellite firmware to the router. (also, make sure to update the satellite first).
