username111
Oct 05, 2023Follower
Can't assign vlan to SXS80
Hey All,
Trying to figure out why I'm seeing some odd behavior. I have a list of vlans, and for some reason when I attempt to assign one specific vlan (222) and apply, it reverts back to default vlan. I have tested it with around 6 other vlans and they all work with no issues. I also can assign vlan 222 to the SXR80 without an issues.
Both SXR/SXS80's are on V4.3.2.100 (latest as of 10/5)
1 Reply
From what I understand you have some VLAN, including 222 and some more defined, and in use on the Orbi Pro WiFi 6 "system", including the SXR80 and (except of one SXS80?) available as an access port, or on trunk. Now you can't make use of the VLAN 222 on one SXS80 - for what purpose? Some screenshots on the VLAN configs would be helpful for the uneducated reader here. You might have to be a little bit more informative please.
