zappe
Mar 26, 2023Aspirant
Captive portal not working - SXR50
zappe
Can’t seem to edit my post. Also not possible to write in the Associated products box here via iPad.
The captive portal doesn’t seem to work on my guest Wi-Fi.
After I click on accept it just send me to the next page, but the pop up in iOS doesn’t say Done so I cannot move forward.
ErwinL
Mar 28, 2023NETGEAR Moderator
Hello zappe,
And welcome to the NETGEAR Community! 🙂
Have you checked the procedures from the link below and see if you have missed any?
https://kb.netgear.com/000061245/How-do-I-set-up-Insight-Instant-Captive-Portal-service
Have a lovely day,
Logan
Netgear Team
- zappeMar 28, 2023Aspirant
So I’m actually just want to set up a guest network, is there any way to do that with out the portal?
- nmhTesterMar 28, 2023NETGEAR Employee Retired
SXK50 support 4 SSIDs.
3 can be enabled without Captive portal splash page.
The customer can create Guest WIi-Fi by using Wireless2 or Wireless3 SSID and enable client isolation.
The guest SSID, other than captive portal, has the client isolation enabled by default.
https://www.downloads.netgear.com/files/GDC/SXK50/WP_NETGEAR_OrbiPro_WiFi6Series.pdf
- zappeMar 29, 2023AspirantCan I get the guest Wi-Fi without the captive portal?
