zappe
Mar 26, 2023Aspirant
Captive portal not working - SXR50
zappe
Mar 28, 2023Aspirant
So I’m actually just want to set up a guest network, is there any way to do that with out the portal?
nmhTester
Mar 28, 2023NETGEAR Employee Retired
SXK50 support 4 SSIDs.
3 can be enabled without Captive portal splash page.
The customer can create Guest WIi-Fi by using Wireless2 or Wireless3 SSID and enable client isolation.
The guest SSID, other than captive portal, has the client isolation enabled by default.
https://www.downloads.netgear.com/files/GDC/SXK50/WP_NETGEAR_OrbiPro_WiFi6Series.pdf
