Zworkon
Nov 22, 2023Aspirant
Chrome Certificate
After the latest updates with chrome, The certificate is not secure and I get this: This site can’t be reached The webpage at https://192.168.x.x/ might be temporarily down or it may have moved ...
- Nov 22, 2023
Here is the solution I found:
We found a fix. Delete the user's local state file located in C:\users\(username)\AppData\Local\Google\Chrome\User Data\Local State. After deleting it the issue went away. Let me know if that works for you.
EDIT: Confirmed this is also happening on MacOS. Need to go to Library/Application Support/Google/ and Delete the Local State file from their as well.Thanks Everyone.
Zworkon
Thanks Everyone.
cowboybizz
Dec 23, 2023Aspirant
The work around deleted the local state in the Chrome/Google folder did not correct my issue. Edge still worms. Any other ideas?
- CrimpOnDec 23, 2023Guru - Experienced User
Have you tried deleting the beta version of Chrome and reinstalling the regular version?
- schumakuDec 23, 2023Guru - Experienced User
One workaround without deleting the "Local State" file or using GPO to disable "RSAKeyUsageForLocalAnchorsEnabled" is to start Chrome with the field trial disabled:
chrome --force-fieldtrials=RSAKeyUsageForLocalAnchors/DisabledLaunch
The proper solution is to create a new certificate for the server with the key usage flag "Digital Signature" enabled.The background is explained for example here in the release notes:
https://support.google.com/chrome/a/answer/10314655?sjid=16333568074522698164-EU#chromBre116&zippy=%2CchromeA lot of work for Netgear engineering updating certificates, including the self signed ones, and distribute updated firmware all over.
Please distribute to all Netgear PMs and Engineers! Sorry for ruining the Xmas and New Year Holidays!
- JaroslawFeb 11, 2024Guide
Will Netgear ever fix that sill certificate error?
