martinav's avatar
Feb 20, 2017
Firewall settings for Chrome Remote Desktop
I need Chrome Remote Desktop to work ASAP.  It worked great until I installed a FVS336Gv3 firewall.  Its the 5th hour now, and still no joy.  I can see computers are online (outside my firewall), but attempts to connect fail from every PC in my network.  CRD works great on my internal network, so local settgs are fine.  Its not Kaspersky or Norton.  It has to be the firewall.  No other explanation.  I need instruction to allow CRD to pass.  The needed information from google:
Your computer's firewall may be configured in a way that doesn't let the app work properly. Verify that your firewall permits outbound UDP traffic, permits inbound UDP responses and allows traffic on TCP ports 443 (HTTPS) and 5222 (XMPP)
I have tried lots of combinations of rule settings in the firewall with no joy.  How the hell do you do it?
Thank you,
Rod
  • Hi martinav,
    If ever you have already configured inbound firewall rules for TCP ports 443 (HTTPS) and 5222 (XMPP) on the FVS336Gv3 that points to the LAN IP Address of your PC, kindly verify if its really open by using an online port scanner like here.
    Let us know the result.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi martinav,
    DaneA
    • martinav's avatar
      martinav
      Guide
      Nothing is open.  Not even 80.
      The checked port (5222, service xmpp-client) is offline/unreachable
      I have no idea if its even done right.  Lets start there.  This is where I left it after worthless hours of messing around with it:
      192.168.157.103 is the internal IP of the PC i'm trying to use to connect to my external PCs.  Please advise...
      • DaneA's avatar
        DaneA
        martinav,
        It seems that you have configured the Services and the LAN WAN Inbound Rules properly.  Hope that the WAN IP Address registered on the FVS336Gv3 is a Public IP Address.
        DaneA
ProSupport for Business
