martinav
Feb 20, 2017Guide
Firewall settings for Chrome Remote Desktop
I need Chrome Remote Desktop to work ASAP. It worked great until I installed a FVS336Gv3 firewall. Its the 5th hour now, and still no joy. I can see computers are online (outside my firewall), but...
- Feb 21, 2017
Hi martinav,
If ever you have already configured inbound firewall rules for TCP ports 443 (HTTPS) and 5222 (XMPP) on the FVS336Gv3 that points to the LAN IP Address of your PC, kindly verify if its really open by using an online port scanner like here.
Let us know the result.
DaneA
NETGEAR Community Team
martinav
Feb 21, 2017Guide
Nothing is open. Not even 80.
The checked port (5222, service xmpp-client) is offline/unreachable
I have no idea if its even done right. Lets start there. This is where I left it after worthless hours of messing around with it:
192.168.157.103 is the internal IP of the PC i'm trying to use to connect to my external PCs. Please advise...
DaneA
Feb 21, 2017NETGEAR Employee Retired
It seems that you have configured the Services and the LAN WAN Inbound Rules properly. Hope that the WAN IP Address registered on the FVS336Gv3 is a Public IP Address.
DaneA
- martinavFeb 21, 2017Guide
Well, does it matter, since I'm not trying to get IN my network, but I'm trying to connect OUTSIDE of my network. This worked great before the firewall. Does having the firewall in some way require some change in my outside IP address? I would not think so.
Thoughts?
BTW, my outside IP is NOT static.
- DaneAFeb 22, 2017NETGEAR Employee Retired
Since you want to remotely connect outside your network using Chrome Remote Desktop, then it seems that there is no need to configure LAN WAN Inbound Rules. However, you might need it if ever there will come a time that you want to remotely connect to your network from outside using Chrome Remote Desktop.
Here are my questions below:
a. If you will connect your PC directly to the modem, are you able to remotely connect going outside your network using Chrome Remote Desktop?
b. Is your modem a modem-only device or a modem-router?
DaneA
