Zworkon
Nov 22, 2023Aspirant
Chrome Certificate
After the latest updates with chrome, The certificate is not secure and I get this: This site can’t be reached The webpage at https://192.168.x.x/ might be temporarily down or it may have moved ...
- Nov 22, 2023
Here is the solution I found:
We found a fix. Delete the user's local state file located in C:\users\(username)\AppData\Local\Google\Chrome\User Data\Local State. After deleting it the issue went away. Let me know if that works for you.
EDIT: Confirmed this is also happening on MacOS. Need to go to Library/Application Support/Google/ and Delete the Local State file from their as well.Thanks Everyone.
ReneD
Mar 04, 2024NETGEAR Moderator
Hello Zworkon,
This is already an ongoing issue and there is a patch firmware that fixes this. Please download the beta firmware on the link provided below and load it to your router and satellite. You can use a firefox browser to login to your GUI and load the firmware provided. After loading the firmware, make sure to perform a full factory default on the router and test if you can use Chrome or Edge after.
Satellite - https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/8b0000016WpK/Nk0fCSwTq8ndt3QrZnhLDk09qDZPcRY6xLBqR.upv3g
Take note to update the satellite firmware first before the router.
Have a lovely day,
Rene D
Netgear Team
Architekt
Mar 04, 2024Apprentice
ReneD Can confirm this fixed this issue for me in Edge and Chrome!!!! For statistics purposes, here are the browser versions I tested it with successfully (all are up to date as of this post, just checked).
Edge: v122.0.2365.66
Chrome: v122.0.6261.95
Firefox: v123.0
Tested with both Windows 11 23H2 and an old laptop (that can't run Win 11) running Windows 10 whatever is the most up to date version.
All 3 browsers now act as they did previously, which is good you connect, you get that same warning about trust etc., click advance and proceed anyway (depends on your browser the exact sequence but I assume by now everyone in this thread knows about this), and boom in you go to the GUI!
I will list a general suggested method to upgrade, as my specific set up is most likely way more complex than other people. If you're curious, my personal set up is this:
- ISP connects to commercial hardware firewall. This firewall also acts as the router.
- I have a Netgear MS510TXM switch that connects via the 10Gbps SFP+ port to the above firewall's 10Gbps SFP+ port. This is the central switch for everything on my network and numerous other ethernet cables connect here (PC, gaming devices, NAS, media server, other switches, etc)
- The Orbi SXK80, in AP mode, has its WAN port (the leftmost one, i.e. the one you'd just connect right to your ISP if you ran it in router mode) connected to the above switch.
- All 3 of my SXS80 satellites connect directly to the above SXK80 router via ethernet backhaul.
Take note of my specific product: these instructions only apply to my experience with my SXK80 and my three SXS80 satellites (2 that came bundled, 1 I bought later on). Also, be aware that I took an ultra paranoid approach to this given the firmware was described as being beta.
General suggestions:
- BACKUP YOUR CURRENT SETTINGS: This will probably differ for each model, but for the SXK80, click on Advanced->Administration->Backup Settings and click the "BACK UP" button at the top where it says "Save a copy of current settings". Make sure this is on hand somewhere not requiring net access. Just put it on your desktop.
- If you are rushing through this, you need to make sure you did step 1, unless you like to start everything from scratch and do things the hard way.
- As per instructions, INSTALL THE FIRMWARE ON EACH SATELLITE FIRST. I did each one at a time. Yes, that took a while, but I was paranoid and wanted to ensure nothing went wrong.
- Once you've updated all your satellites, now you can update the router.
- Yes, you do have to do a factory reset. As a test, I tried connecting w/out doing so and obviously it didn't work. Before you factory reset, please keep reading.
- I unplugged every satellite, so that at this point only the router was powered on.
- Now I did the factory reset. Follow the instructions for your model. If you don't know how, it's in the user manual. For my model it was towards the bottom at the appendix area. Just search for "factory".
- For my model, after the front LED blinked white (indicates booting up) for a while, it turned solid white for a while (indicates factory reset in progress).
- I directly connected my ethernet cable from my laptop to the router (not sure if this is required or you can just use wifi, but I wanted to be extra careful)
- I am not sure once it's solid white how long you need to wait but I got bored after a few minutes and decided to try connecting to the router. My model's factory default IP address is 192.168.1.1 so I opened Firefox (again, being paranoid, decided to keep using same browser as before, possibly not necessary) and connected directly to it. I then got the standard fresh out the box "let's set up your Orbi!" walkthrough.
- Follow the set-up instructions and you'll quickly be given a choice to start from scratch, or here's why you should have read step 1, restore your router configuration from a backup file. I selected this option and uploaded the config from step 1.
- I waited until the router was all done, verified I could connect with Firefox, then verified I could connect using Edge and Chrome (which previously wouldn't): it worked.
- Again, probably being overly paranoid, but I plugged back in each satellite one-by-one. By that I mean I waited until the front LED on each satellite remained on for the 3m the manual says it will do, and then it eventually turned off, indicating successful connection to the router.
- Profit. Issue resolved in Edge and Chrome with no regedit or other workarounds needed.
ReneD If you're curious, I have my router set to syslog everything to my NAS and got a bunch of warnings/errors the first time I powered on the first satellite (15 to be exact), after which point it seemed to reboot itself, gave me 3 more errors, and then fixed itself with no other errors at all. For the subsequent 2 other satellites, I simply got the same 3 errors instead of the initial 15. Once again, this didn't cause any problems: the satellites correctly fixed themself. If you want, I can send you the messages the syslog server sent me (just tell me the appropriate way to send them to you).
Once again, thanks!
