Zworkon
Nov 22, 2023Aspirant
Chrome Certificate
After the latest updates with chrome, The certificate is not secure and I get this: This site can’t be reached The webpage at https://192.168.x.x/ might be temporarily down or it may have moved ...
- Nov 22, 2023
Here is the solution I found:
We found a fix. Delete the user's local state file located in C:\users\(username)\AppData\Local\Google\Chrome\User Data\Local State. After deleting it the issue went away. Let me know if that works for you.
EDIT: Confirmed this is also happening on MacOS. Need to go to Library/Application Support/Google/ and Delete the Local State file from their as well.Thanks Everyone.
Architekt
Mar 04, 2024Apprentice
ReneD Can confirm this worked. I posted a very detailed reply about what I did but for some reason said post got rejected and seems to be awaiting moderator approval after I edited it because an angry face emoji somehow accidentally appeared, I think due to how I ended my parenthesis.
ScubaSteve007
Mar 06, 2024Guide
Chrome and Edge will not access the Management Login on the SXR80. The only way in is by using Firefox and this concerns me if this stops. Firmware is up to date. recently windows and chrome updates are the reason this has stopped working.
There are no options to change setting from http to https or vice verse and to make matters worse I can not log a case with netgear without paying $$$$ for a contract for them to look at and fix an issue with their browser compatibility.
Any ideas welcome as nothing in the thread here works. 1 screen shot showing chrome (left) error) whilst Firefox (right) logged in.
- schumakuMar 06, 2024Guru - Experienced User
Unluckily, ScubaSteve007 's post was moved here from the Orbi WiFi 5 section to this thread by a moderator, by error without my original reply.
The answer to the post above was given before here before. Netgear has released a patch for the SXR80 and SXS80 before.
- Chippy_boyMar 06, 2024Aspirant
Hi folks - hope someone can help?
I have an SXR80 and two SXS80 satellites. System is working fine and I am very happy with it.
However, I have a weird problem. I am primarily using Windows 11 and Edge browser and today I find I cannot access the Orbi login pages over my lan. At first I get the usual "Your connection isn't private" warning, but then when proceding, I get the following error:
Hmmm… can't reach this page
It looks like the webpage at https://192.168.55.51/ might be having issues or it may have moved permanently to a new web address.
ERR_SSL_KEY_USAGE_INCOMPATIBLEThe strange thing is, I can still access the same IP/webpage using Firefox and it also works fine from my Mac with Safari! Also, I tried Chrome and that CANNOT access the Orbi either, with the same errors. So Safari and Firefox both work but both Chromium-based browsers do not!I have tried the foilowing:Cleared cache & cookiesipconfig /flushdnsTried Edge in Private ModeDisabled all extensionsDoes anyone have a clue what might be going on here? I am really stumped.Thanks- schumakuMar 06, 2024Guru - Experienced User
