Zworkon
Nov 22, 2023Aspirant
Chrome Certificate
After the latest updates with chrome, The certificate is not secure and I get this: This site can’t be reached The webpage at https://192.168.x.x/ might be temporarily down or it may have moved ...
- Nov 22, 2023
Here is the solution I found:
We found a fix. Delete the user's local state file located in C:\users\(username)\AppData\Local\Google\Chrome\User Data\Local State. After deleting it the issue went away. Let me know if that works for you.
EDIT: Confirmed this is also happening on MacOS. Need to go to Library/Application Support/Google/ and Delete the Local State file from their as well.Thanks Everyone.
ReneD
Mar 04, 2024NETGEAR Moderator
Hello Zworkon,
This is already an ongoing issue and there is a patch firmware that fixes this. Please download the beta firmware on the link provided below and load it to your router and satellite. You can use a firefox browser to login to your GUI and load the firmware provided. After loading the firmware, make sure to perform a full factory default on the router and test if you can use Chrome or Edge after.
Satellite - https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/8b0000016WpK/Nk0fCSwTq8ndt3QrZnhLDk09qDZPcRY6xLBqR.upv3g
Take note to update the satellite firmware first before the router.
Have a lovely day,
Rene D
Netgear Team
ScubaSteve007
Mar 06, 2024Guide
Thanks for the information re Beta but is a Factory Default seriously required? We have 2 kits each with 1 Router and 6 Satellites and that's a lots of time and effort to repare and set them up again 😞
- ArchitektMar 06, 2024Apprentice
ScubaSteve007 I mentioned a general guideline of steps after the firmware links. In my set up, I have 3 satellites. I only performed a factory reset on the router. I did not reset any of the satellites. I don't know if you have to do so, but every since I applied the patch I haven't had any wi-fi issues or issues connecting to the actual router.
- ScubaSteve007Mar 06, 2024Guide
Thanks understood, but if you factory reset the Router then it loses the Satelite information and they have to be paired back to the router 1 by 1
That's why you back up your settings before you firmware reset and then simply upload those settings back to the router instead of starting to set up from scratch. I had zero loss of satellite information whatsoever, no pairing required. Again, it's critical to back up your settings and restore them. Also, again, in the detailed instructions, I mention that as a just-in-case, I took the paranoid approach and unplugged each satellite (after applying the patch and they restarted completely), then did the factory reset on the router. I literally didn't have to do anything after I uploaded the backed up config besides plug back in the satellites.
