Zworkon
Nov 22, 2023Aspirant
Chrome Certificate
After the latest updates with chrome, The certificate is not secure and I get this: This site can’t be reached The webpage at https://192.168.x.x/ might be temporarily down or it may have moved ...
- Nov 22, 2023
Here is the solution I found:
We found a fix. Delete the user's local state file located in C:\users\(username)\AppData\Local\Google\Chrome\User Data\Local State. After deleting it the issue went away. Let me know if that works for you.
EDIT: Confirmed this is also happening on MacOS. Need to go to Library/Application Support/Google/ and Delete the Local State file from their as well.Thanks Everyone.
ScubaSteve007
Mar 06, 2024Guide
Thanks for the information re Beta but is a Factory Default seriously required? We have 2 kits each with 1 Router and 6 Satellites and that's a lots of time and effort to repare and set them up again 😞
Architekt
Mar 06, 2024Apprentice
ScubaSteve007 I mentioned a general guideline of steps after the firmware links. In my set up, I have 3 satellites. I only performed a factory reset on the router. I did not reset any of the satellites. I don't know if you have to do so, but every since I applied the patch I haven't had any wi-fi issues or issues connecting to the actual router.
