Zworkon
Nov 22, 2023Aspirant
Chrome Certificate
After the latest updates with chrome, The certificate is not secure and I get this: This site can’t be reached The webpage at https://192.168.x.x/ might be temporarily down or it may have moved ...
- Nov 22, 2023
Here is the solution I found:
We found a fix. Delete the user's local state file located in C:\users\(username)\AppData\Local\Google\Chrome\User Data\Local State. After deleting it the issue went away. Let me know if that works for you.
EDIT: Confirmed this is also happening on MacOS. Need to go to Library/Application Support/Google/ and Delete the Local State file from their as well.Thanks Everyone.
MrMcBic
Mar 24, 2024Aspirant
The links to that firmware have expired already.
ReneD
Mar 25, 2024NETGEAR Moderator
Hello SteMo/@MrMcBic,
And welcome to the NETGEAR Community! 🙂
Please use the below link instead.
SXR80
SXS80
Have a lovely day,
Rene D
Netgear Team
- schumakuMar 25, 2024Guru - Experienced User
Thank you ReneD !
Do you have the V4.3.2.1001356-like fix-builds for SXR30/SXS30 and SXR50/SXS50 available, too?
- SteMoMar 25, 2024Tutor
Thanks ReneD!!!!!
I'll proceed with the installation right away!
Thanks again :))- ScubaSteve007Mar 25, 2024Guide
Just completed the upgrade and all good using this firmware, Follow all the steps and you'll be fine
- JaroslawMar 25, 2024Guide
Unfortunately, I see no changes after upgrade of SXS80-V4.3.2.1001356-signed to my router. Same chrome error.
I wonder if it works for you.
I did that upgrade with no effect. Still same issue with Chrome.
No access from Chrome nor Edge.
Firefox and IE work
Thanks everyone for the help! Updated and everything works 🙂
