Zworkon
Nov 22, 2023Aspirant
Chrome Certificate
After the latest updates with chrome, The certificate is not secure and I get this: This site can’t be reached The webpage at https://192.168.x.x/ might be temporarily down or it may have moved ...
- Nov 22, 2023
Here is the solution I found:
We found a fix. Delete the user's local state file located in C:\users\(username)\AppData\Local\Google\Chrome\User Data\Local State. After deleting it the issue went away. Let me know if that works for you.
EDIT: Confirmed this is also happening on MacOS. Need to go to Library/Application Support/Google/ and Delete the Local State file from their as well.Thanks Everyone.
schumaku
Mar 25, 2024Guru - Experienced User
Thank you ReneD !
Do you have the V4.3.2.1001356-like fix-builds for SXR30/SXS30 and SXR50/SXS50 available, too?
