Trickyricky
Apr 17, 2022Follower
Corrupt firmware
Orbi Srs 60 wired backhaul firmware V.7.2.0.122
when i turn the satellite on I get a flashing red light at the switch, which means i have corrupt firmware. I have tried the set to factory settings to no avail.
the unit is out of warranty.
What do I do??
thanking you in advance
Richard
Flashing red light at the switch? Not at the orbi?
Did you try it with it disconnected from switch/router?
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash- CrimpOnGuru - Experienced User
I think "switch" means the power button on the back of the unit, right next to the LED.
