eierughdf
Jul 09, 2023Tutor
CVE issues with SXR80
 i had chose netgear when buying the SXR80 because it seemed they put out regular firmware updates for the life of the products. Well this year i've not seen any firmware updates for the Orbi SXR80 be...
eierughdf
Jul 09, 2023Tutor
Correction, not CVE issues but these are security issues that should be fixed:
Missing 'Secure' Cookie Attribute (HTTP)
Missing 'HttpOnly' Cookie Attribute (HTTP)
DNS Cache Snooping Vulnerability (UDP) - Active Check
SSL/TLS: Deprecated TLSv1.0 and TLSv1.1 Protocol Detection
SSL/TLS: Diffie-Hellman Key Exchange Insufficient DH Group Strength Vulnerability
also update openSSL and certs so that your VPN works with the latest version
of openVPN without havinng to enable legacy settings.
