komaroff
Sep 05, 2022Follower
SXR80 satellite compatibility
Dear community,
Can't find on Netgear page if it's possible to connect SXS30 or SXS50 satellite to SXR80 router?
Both SXS50 and SXR80 are 3-band, so sholdn't be any problem, right?
Tnx!
Vitaly
No. SXK30/80 are compatible. SXK50 is not compatible with other Orbi Pro models.
from the release notes on 4.0.0.118, they've added compatiblity. Not sure about the SXR50 as that was released after
SXR80 / SXS80 Firmware Version 4.0.0.118 | Answer | NETGEAR Support
