BrainSuperGlue's avatar
Jun 05, 2022
Disable bar LED on SXK30
Hi, Looked through the manual and advice for other Orbi / Orbi Pro on how to turn off the bar LED but cannot find it. How DO you disable the bar LED on an Orbi Pro SXK30? Thanks BSG
ProSupport for Business
