mokeb
May 27, 2021Aspirant
Does OrbiPro Wifi 6 (SXK80) support WAN link aggregation?
Looking to use SXK80 with MB8600 modem using link aggregation on the orbi's wan port. Does this model (specifically the SXR80 router) support that connection? If so, how is the SXK80 configured for...
BruceGuo
Jun 01, 2021NETGEAR Expert
Hi
Go to ADVANCED -> Setup -> WAN Setup
Choose the WAN port as “Port 2(1G)” and APPLY
Then, go to the switch setting and enable LAG on port 2 and 3.
Bruce
mokeb
Jun 02, 2021Aspirant
I tried these steps previously without success when connecting to mb8600 modem with link aggregation enabled. Have you been able to get it to work?
- BruceGuoJun 06, 2021NETGEAR Expert
Hi
SXK80 only supports static LAG on WAN port. What's LAG mode the modem "mb8600" supports?
Bruce
