Djh11375
Jan 11, 2021Aspirant
Ethernet backhaul: dedicated switch?
Do I have to use a dedicated switch to connect satellites back to the router, or will they find each other on a shared switch?
schumaku
Jan 11, 2021Guru - Experienced User
Depends ...
What kind of switch or switched network infrastructure?
Which Orbi Pro system exactly?
- Djh11375Jan 11, 2021Aspirant
Model is SRR60
We have ethernet jacks wired to each room, that go through one "central" switch. So, can I plug a Satellite into a jack that feeds back to this switch? (And if so, do I plug into the yellow jack on the satellite?)
