jcharnet
Jun 17, 2021Guide
Ethernet Backhaul Fair Status
I’m connecting SXR80 with SXS80 satellite through Ethernet backhaul. But the Mesh Link Status shows Fair. How is that possible? Am I missing any settings? Thank you, Joao
- Jul 05, 2021The solution for me was to factory reset my Satellite, since I had replaced my router recently.
Thank you for all the help.
schumaku
Jun 24, 2021Guru - Experienced User
Best guess is you will always see the wireless backhaul status, even if there is a mostly reliable wired backhaul. BruceGuo please advise.
ChristineT please ensure all newer hardware - kits as well as individual routers and satellites SKUs - are becoming available for product tagging in the community.
michaelkenward
Yes please.
It confuses the hell put of people and gives the impression that Netgear does not support their hardware. If something appears in the "Support" search it should also appear in the community dropdown.
- RaghuHRJun 24, 2021NETGEAR Expert
Hi jcharnet
Please share the debug logs of your router and satellite. We will investigate and update you.
Go to https://<ip address of router/satellite>/debug.htm
Click on start capture.
Wait for few mins
Save debug logs and upload debug logs into google drive or one drive. Send me link to download via PM.
Thanks,
Raghu
- jcharnetJul 05, 2021GuideThe solution for me was to factory reset my Satellite, since I had replaced my router recently.
